Discussion topic: Sky mini not working
This message was authored by: Rolling
I have relocated the Sky mini to a new location (was connected via Ethernet). When the mini setup sequence starts (new location) I get to the press the 'home' button when the screen goes blank and nothing further happens, the mini does not respond to anything from the remote.
I've tried a 30 sec reboot and a back of the box reset, still nothing. Remote has new batteries, the tv turns off after 3 sec using the Sky remote and the tv volume responds to the Sky remote.
Any suggestions?
Re: Sky mini not working
Any suggestions?
Hi @Rolling
Try pressing and holding 7 & 9 together on the remote until it's led flashes 4 times.  This will set the remote to infrared mode which will then control and Q box within line of sight.
Then reboot the mini again.
To reboot press Standby on your min remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini Q box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the Q box (Amber led).
Remember that the remote is in infrared mode and so must be pointed directly at the mini box.
Of you can get the mini working re pair the remote by pressing 1 & 3 together on the remote until its led flashes and follow onscreen instructions.
