2
This discussion topic has been answered Discussion topic: Sky mini connection issues with main box
This message was authored by: barneyman2002
Ever since the firmware update I am getting regular issues on the mini box where the picture freezes, then comes up with a message saying lost connection with main box, then a few seconds later the picture comes back!
anyone else? Anything I can do before contacting sky?
thanks!
Re: Sky mini connection issues with main box
thanks!
Hi @barneyman2002
Reboot the mini as above.
thanks!
Hi @barneyman2002
Avatar for barneyman2002
Level 2 icon
Thanks, have tried this so let's see if it works 😀
