Discussion topic: Sky mini boxes not connecting
Message posted on 09 Aug 2023 06:44 PM
I've had a power cut and now the only box that's working is my sky Q l have 4 mini's and there not connecting I've followed the on screen advice to link them but nothing is working?
Message posted on 09 Aug 2023 06:53 PM
Re: Sky mini boxes not connecting
Hi @Dan-sum
Reboot the minis as above.
Start with the one nearest to the main Q box and then the next nearest etc.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. You can also use WPS on a previously connected mini if nearer.
