5
This discussion topic has been answered Discussion topic: Sky mini boxes all broken after update
This message was authored by: Dave+on+the+beach
Since the recent update to 5u193hm on my sky mini boxes they ate all having connectivity issues.
I've reset the connection
I've tried ethernet and wifi.
I've tried the dumbest troubleshooting on sky's website I've ever seen!
I have superb Internet at 2.2Gbps with Vodafone and every other device works flawlessly.
So what do I try now? This is the screen is get....
Avatar for Dave+on+the+beach
Level 3 icon
This message was authored by: Dave+on+the+beach Answer
Re: Sky mini boxes all broken after update
The Vodafone router is have uses 2.4 5 and 6ghz.
However I found the cause of the issue!
The brand new amazon echos! We replaced all 4 of the echos we had with the newest versions. Put them in the same place as before which was next to the mini boxes.
One echo failed and that ski mini box suddenly started working properly!!
So removed the others and they all started working!
So the new echos were messing g with the sky minis!. To be sure I plugged the old echos in and they had no effect on the sky equipment! New ones do! They are now on the other side of the rooms to the sky minis. Everything now works.
I did discover i can only have 4 sky mini boxes not 5! One very rarely used sky mini was never actually on in the gust bedroom. But hey alls working at last!
...except Q to Q connectivity doesn't use your internet connection.  It uses it's own 5GHz mesh at channels 36 to 48 by default.
Ensure your vodaphone router is not using this range.
Hi @Dave+on+the+beach
Reboot the mini as above.
Have you tried a Reactivate? That always works for me when I get that message, which didn't happen for me when this firmware upgrade rolled out but has randomly in the past.
This message was authored by: Andy+Wilkinson
I have had similar issues after the update. Main Q box freezes with high fan speed after 3-5 mins of operation, crashes all mini boxes and becomes unusable. I have just done a forced update (power off, power on with main button pressed). That was unfruitful. So I went into the engineer menu (settings, 001 select) then did a factory reset. This appeared to work for 10 mins then returned to high fan speed and crashed again. I will now need to contact sky to get the box replaced. Not happy.
Level 3 icon
