Discussion topic: Sky mini box
Message posted on 30 May 2025 03:43 PM
Sky mini box
Hi , could anybody tell me why my sky mini box keeps freezing after about a minute. I've connected ok, tried turning everything off and rebooted both mini and main box but my mini box keeps freezing
Message posted on 30 May 2025 04:12 PM
Re: Sky mini box
Hi @GrahamM1
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 30 May 2025 04:45 PM
Re: Sky mini box
Thanks mate, I'll try that. It was working fine till about a week ago, then I got a text off Sky saying there had been a fault with there Sky Q boxes and it's never been the same since!!
