Discussion topic: Sky mini box
This message was authored by: Bubbly+boo
Sky mini box
Hi my mini box is not connecting even though it says it is connected to my WiFi? I have tried everything to it tells me to do with same outcome.
Re: Sky mini box
Hi @Bubbly+boo
Reboot the mini as above.
