Discussion topic: Sky mini box
Message posted on 10 Oct 2023 07:56 PM
Sky mini box
Hi
I have a sky mini box which is currently in a TV cabinet behind a door. The only way I can change this currently is by opening the door which is frustrating.
Based on the above, would my only optin be to purchase a 'magic eye' and if so, does anyone have any experince of these?
Mike
Message posted on 10 Oct 2023 08:11 PM
Re: Sky mini box
Hi @MikeHardy1973 You simply need to pair a Voice Control remote (current default) to the box and it will work by Bluetooth. You will need line of sight to pair it the first time. There is no "magic eye" with Sky Q as it is not required.
Message posted on 10 Oct 2023 08:16 PM
Re: Sky mini box
Thanks but I don;t have voice control on the controller as it is for the mini box not the main box? Sky don't have magic eye but if you google it, this seems to be an option?
Message posted on 10 Oct 2023 08:27 PM
Re: Sky mini box
@MikeHardy1973 wrote:Thanks but I don;t have voice control on the controller as it is for the mini box not the main box? Sky don't have magic eye but if you google it, this seems to be an option?
The best option would be to get a BT remote - Sky might send you one for free if you ask nicely.
Any IR repeater ('magic eye') could be problematic.
Message posted on 10 Oct 2023 08:30 PM
Re: Sky mini box
Thanks but ask a stupi question, if i do get a voice controlled controller, how do you scroll when searching the TV guide?
Message posted on 10 Oct 2023 08:34 PM
Re: Sky mini box
@MikeHardy1973 wrote:Thanks but ask a stupi question, if i do get a voice controlled controller, how do you scroll when searching the TV guide?
The arrow buttons are still there...
Message posted on 10 Oct 2023 08:35 PM
Re: Sky mini box
Thanks and will give this a go.
