Discussion topic: Sky mini box will not connect
Message posted on 13 Jul 2026 04:29 PM
Hi. The issue is at my parents in laws house. They have a Sky Q main box. And one Sky mini box (in their bedroom ). The system was all okay and working well until Sky sent them a new router last week.
now I can not get both boxes to connect at the same time I've followed on line advice. I've turned everything off. Router on first. Main sky box. Connect to router. Mini box on if u connect to router it knocks main box connection out. If I connect to main box thd connection lasts maybe a minute or two before losing connection. Any help would be greatly appreciated
Message posted on 13 Jul 2026 04:46 PM
Re: Sky mini box will not connect
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 14 Jul 2026 08:15 PM
If you have one of the new hubs you have to connect the main SKy Q box as if you are using broadband supplied by someone else and have to mannually enter the settings.
Mine has been working firn for months, but now the main Sky Q and one mini is conneted, but the other mini fails to connect. Sometimes it comes back that it hasn't been able to get an IP address and others it just fails in its connection attempt to the main Sky Q box when you reset and do a discovery.
Message posted on 15 Jul 2026 02:33 PM
Thank you for your reply. It worked for a moment and then disconnected.
Message posted on 15 Jul 2026 02:35 PM
Thank you for your reply. It did not work that unfortunately
Message posted on 15 Jul 2026 02:38 PM
One of the many messages displayed was "there appears to be a problem with your router which means it is not issuing IP addresses (MR002)."
That's a new message. All the other messages I've had have been saying no connection to the main sky Q box. It's very frustrating as their system worked perfectly until Sky replaced their router
Message posted on 15 Jul 2026 02:42 PM
Had that yesterday and powered everything off including the router and then restarted router first that was working correctly, but did it any way. Once router was up and everything else connected I was able to reset the mini and get it to connect successfully with the main SKy Q box.
I think there's either been an update or its the heat causing issues.
