Discussion topic: Sky mini box stopped working
Message posted on 11 Dec 2023 09:57 PM
Hi my sky mini box just shut off earlier and now won't worked. Checked status on main box and all looks okay and connected. Remote seems to have stopped working also. Mini box will only turn on by button on box and stuck at trying to connect to internet now. Can't come out of page as remote isn't working. Pressed 7&9 together on remote ba dot doesn't do anything nor does 1&3 either. What could this be? Thanks
Message posted on 11 Dec 2023 10:10 PM
							Re: Sky mini box stopped working
Hi @Glenners1
Try using your main Q remote to see if this will work the mini.
You need to completely reset it as follows:
Mini needs to be on with Green led.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
When you want to use it again for your Q box just repeat the above procedure using the main Q box.
Message posted on 11 Dec 2023 10:15 PM
Thanks. I did that and it started giving me the options to connect the remote. Got right through to 'finish' and then won't let me select it or do anything else?
Message posted on 11 Dec 2023 10:18 PM
Hi @Glenners1
Try just pressing the 7 & 9 until the remote led flashes 4 times again.
Then don't try to pair it but see if it will work the mini. It will be in infrared mode and so you need to point it at the mini when you try it.
Message posted on 11 Dec 2023 10:23 PM
That has worked now thankyou. The mini won't connect to the main sky box now
Message posted on 12 Dec 2023 09:39 AM
Hi @Glenners1
Reboot the mini as above.
Message posted on 13 Dec 2023 08:58 AM
Thanks...nothing worked. Spoke to Sky yesterday and the box was stuck in standby so they are sending me a new one 🙂
Message posted on 13 Dec 2023 01:59 PM
@Glenners1 if they are sending you a new box via DPD it will be a doorstep swap where DPD will expect the old box to be unplugged and ready to be collected and they will take the old box when they give you the new box
REMEMBER TO REMOVE YOUR VIEWING CARD FROM THE OLD BOX it is situated on the right hand side of the box towards the front
