Discussion topic: Sky mini box problem
Message posted on 26 Feb 2024 05:03 PM
We moved the sky Q mini box from one room to another - now it won't recognise the main Q box and on the main Q box it says we don't have a mini box on this account!
Message posted on 26 Feb 2024 05:18 PM
Re: Sky mini box problem
Reboot the mini as above.
