Discussion topic: Sky mini box not working
Message posted on 17 Aug 2024 01:00 PM
My sky mini box is not working
Message posted on 17 Aug 2024 01:20 PM
							Re: Sky mini box not working
Hi @suzie6113
Reboot the mini as above.
