Discussion topic: Sky mini box not working.
Message posted on 23 May 2024 08:51 PM
Sky mini box EM150 has stopped working.
Message posted on 23 May 2024 08:52 PM
Re: Sky mini box not working.
Hi @Hedehog
Reboot the mini as above.
Message posted on 23 May 2024 09:03 PM
Sky mini used to work now it won't, can you just send us a new EM150 sky box.
Message posted on 23 May 2024 09:10 PM
Hi @Hedehog
This is mainly just a customer forum where other customers like myself try to help.
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
https://www.sky.com/help/home
