Discussion topic: Sky mini box needs resetting everyday !
This message was authored by: ChrisH1991
Hi all,
Sky Q mini keeps needing to be plugged out and put back in ....it states no internet but my internet is fine on the main box and overall .....tried resetting, resetting remote etc and sometimes it turns off and won't go back on .....very annoying it's 4 years old - could it be a software problem with the main box ?
Re: Sky mini box needs resetting everyday !
@ChrisH1991 wrote:
Hi all,
Hi @ChrisH1991.
More likely an issue  with connection or distance between mai Q bo and mini.
Have you correctly completely the following.
Reboot the mini as above.
Avatar for ChrisH1991
Thank you I have reset the main box loads and reset - I'll try again and see the sky q mini is only a few feet away from the main box - thank you
