Discussion topic: Sky mini box keeps disconnecting from main box
Message posted on 09 Aug 2023 08:52 PM
My sky mini box keeps disconnecting from main box. Tried software updates, checking signal! Any advice would be appreciated thanks
Message posted on 09 Aug 2023 08:54 PM
Re: Sky mini box keeps disconnecting from main box
Hi @Cheryl8406
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing all this you may need a Sky Q WiFi booster to position midway between the main Q box and the mini.
