Discussion topic: Sky mini box keeps cutting off at 2:30am
This message was authored by: Stacyh88
My sky q mini box cuts off at 2.30am on the dot every morning, I can't connect it back up until the morning , nothing will get it working. It's literally on the dot!!
The internet cuts off and a message comes up saying there's an issue with the connection between this mini box and your sky Qbox , there is nothing I can do to connect them back up to watch through the night
I've checked the settings on my sky box and the main sky q box, none of the settings are in eco or active mode. They are both set to NONE. Is there anything else I can try please?
TIA
This message was authored by: Mr+Flibbles+86
Re: Sky mini box keeps cutting off at 2:30am
Posted by a Sky employee
TIA
Hi @Stacyh88
Suspect that the main Q box and possibly also the mini are in Eco Standby.
Double check both boxes to confirm.
See the following link.
https://www.sky.com/help/articles/using-the-standby-settings
Change your settings to Active on both boxes.
Avatar for Stacyh88
I've checked, they are both of the off mode
Hi @Stacyh88
Try a Reset Settings in the main Q box hidden menu.
When the box is back up and running check that is still in Standby mode None.
This message was authored by: Tom-W19
Hi @Stacyh88
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
