Discussion topic: Sky mini box is freezing
Message posted on 19 Nov 2023 11:48 AM
Hi, I have a sky mini box and it keeps freezing when watching live tv or recordings. I have reset the box and no joy. This mini box is in the same room as the sky dish is on the wall of. Out main sky box is downstairs and works perfectly. Thanks
Message posted on 19 Nov 2023 12:28 PM
Re: Sky mini box is freezing
Hi @Carly8
The fact that mini is near the dish is irrelevant as it needs to connect to main Q box WiFi (or the Router WiFi if on Sky broadband.
Try a Network Reset on the mini.
Message posted on 19 Nov 2023 05:43 PM
Thank you very much for your reply, I have sky broadband and the router is in the same room as the mini box so have reset and connected to the router instead of to the main box downstairs.
Fingers crossed that's the answer, thanks again!
Message posted on 19 Nov 2023 06:20 PM
