Discussion topic: Sky mini box has permanent red light
Message posted on 10 Jul 2023 05:46 PM
My sky mini box is stuck on the red light. Not turning on at all. Followed all the steps. Remote flashes when you press ?
switched the box off and on. Switched off for 20 mins and still nothing. Switched off and pressed home keys for 20 secs just after. Nothing still
Message posted on 10 Jul 2023 06:13 PM
Re: Sky mini box has permanent red light
Hi @Dev+jheeta
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
