Discussion topic: Sky mini box connection
Message posted on 15 Nov 2024 07:26 PM
Sky mini box losing connection to Sky Q box within last week and having to be re set daily.
Message posted on 15 Nov 2024 09:30 PM
Re: Sky mini box connection
Hi @POrmistn19
Have you tried completly resetting it as follows:
Reboot the mini as above.
