1
This discussion topic has been answered Discussion topic: Sky mini box connec
This message was authored by: ACS38
Sky mini box connec
I have a 2nd Toshiba tv that connected via a Mini box but since changing my broadband it's stopped working . I can't access sky on my tv to get to settings
Re: Sky mini box connec
Hi @ACS38
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @ACS38
