Discussion topic: Sky mini box box connecting
This message was authored by: Jan02
My Sky mini box occasionally disconnects, but normally manage to connect after a bit.  This time though it just willl not connect! Have tried the reset, turned off at mains, re started the main box but still just will not connect. Any ideas?
Re: Sky mini box box connecting
Hi @Jan02
Reboot the mini as above.
This message was authored by: lindadl
FYI I was told today that Sky no longer provide sky q boosters free of charge and you have to purchase one.
