Discussion topic: Sky max with sky q
Message posted on 02 Apr 2026 08:22 PM
Sky max with sky q
Just got full fibre and have new black router but WiFi not getting to upstairs . They are sending me max with pod but read doesn't work with sky q
Message posted on 03 Apr 2026 07:46 AM - last edited: 03 Apr 2026 07:46 AM
Re: Sky max with sky q
A Max Hub and its pods don't participate in the 'Q Mesh' : by itself the Max Hub can supply the main Q box with an internet connection just as any other router would.
Message posted on 03 Apr 2026 08:08 AM
I've never had multi-room with Q but do the mini boxes still connect with the main box or directly with the Max Hub router via the pod/booster?
I read the OP's post as saying it doesn't connect with a 2nd box upstairs?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 03 Apr 2026 08:41 AM - last edited: 03 Apr 2026 08:42 AM
As indicated by @TimmyBGood the SKY Max system is effectively treated as '3rd party wifi' by SKY Q - so the SKY Q minis do not connect to it & thus use the wifi generated by the Main Box
Message posted on 03 Apr 2026 08:41 AM - last edited: 03 Apr 2026 08:44 AM
Hub to main Q box, then main Q box to Mini boxes.
The 2016 Q Hub and 2019 Broadband Hub models are 'Sky' products built using the same proprietary mesh technology as Q television boxes (also released in 2016) : the 2023 Max Hub is a Comcast product.
Message posted on 03 Apr 2026 09:02 AM
Cheers. So if I'm correct about @gunners33 having issues connecting to a mini box, the Max will make no difference?
Not a Sky employee
