Discussion topic: Sky main event bad quality
Message posted on 22 Feb 2026 02:25 PM
My sky sports main event has a poor quality picture and sound since Friday night. Other sky sports channels are fine
Message posted on 22 Feb 2026 02:33 PM
Re: Sky main event bad quality
Any on-screen error message.?
I'm also watching Forest v Liverpool, albeit on my mini box in HD and the picture is fine for me.
Message posted on 22 Feb 2026 02:38 PM
Watching the same. The picture is fuzzy and the commentary is a second behind. I don't have any message about fault or error
Message posted on 22 Feb 2026 02:42 PM
No picture or sound issues here.
Perhaps at half time, if you haven’t done it already, it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 22 Feb 2026 02:48 PM
Having same issue, tried rebooting but still the same
Tnt sports is ok
Any issues from sky
Message posted on 22 Feb 2026 02:51 PM
I've tried rebooting.. All other channels are fine, just main event.. had the same problem trying to watch a match yesterday
