Discussion topic: Sky keeps going off and telly just says there is no signal
This message was authored by: Syoung1
When I turn TV on sky will come on then within 30 seconds it goes off and the TV says there is no signal
Re: Sky keeps going off and telly just says there is no signal
@Syoung1
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
