Discussion topic: Sky installation
This message was authored by: Newproperty9
Sky installation
Had sky tv installed 5 weeks ago where they drilled through the wall for the cable to go through they them covered it with clear silicone and put a cover over this.
the cover has since come off and blown away in the wind . How do I contact an engineer to fix this please
This message was authored by: NickNewark
Re: Sky installation
It's probably something you can pick up online, and reattach yourself, and engineer would probably cost more.
@Newproperty9 I'm surprised they fitted a cover. In the past it's just been silicone filler to seal the holes.
