Discussion topic: Sky hub returns
This message was authored by: Dunc
Sky hub returns
I had a home move so took exsisting Q hub to new property, the install engineer used the same hub to set up. Sky are requesting hub be returned or they will charge for none return, I cannot physically talk to anyone from sky to explain hence why asking here. Anyone help please
Re: Sky hub returns
hi @Dunc
I have escalated your post to a SKY support team, who, hopefully, will be in touch.
Please see this link re the escalation and what you might see:
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings  to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
This message was authored by: Addie15
Re: Sky hub returns
Hi there! Thank you for escalating this. We have sent an invite to Dunc.
Re: Sky hub returns
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
This message was authored by: Greenfingers001
Re: Sky hub returns
Update:
Spoke with @Dunc and resolved issue.
Thanks again for the escalation have a great afternoon 🙂
