Discussion topic: Sky extra mini box
Message posted on 28 Dec 2025 09:29 PM
Sky extra mini box
I have a sky mini box and would like another one. Is there a charge to have another box? I was offered a second box on connection but declined at the time.
Message posted on 28 Dec 2025 10:04 PM
Re: Sky extra mini box
Yes there is a one off upfront loan cost for additional minis.
You could try negotiating with Sky but normally only the first mini is sometimes loaned free.
However the monthly Multiscreen subscription covers all minis
Message posted on 29 Dec 2025 02:51 AM
@barann33
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
Message posted on 29 Dec 2025 09:29 AM
Just checked and it's saying hardware version 32D00D wondering now if I could have another mini box now 🤔
Message posted on 29 Dec 2025 09:42 AM
32D** is the version of your mini box. You need to check the version of the main Sky Q box.
