Discussion topic: Sky extension box only showing 2 lights
Message posted on 25 Jan 2026 01:48 PM
Since BT broadband upgrade my sky box connection to the second TV only has 2 lights showing so connection keeps dropping off
Message posted on 25 Jan 2026 06:22 PM
Re: Sky extension box only showing 2 lights
@PJH6 If you have a Sky Q booster for your mini box then it needs to be placesd midway between your main box and mini box and needs to be connected to you main Q box and your mini box.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jan 2026 06:56 PM
Hi @PJH6
On any Broadband you can use the WiFi booster to connect to your router or your main Q box. That's provided it is a Sky Q WiFi booster.
If you main Q box is successfully connected to your router then you can use the Q booster located between your main Q box and the mini.
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
- Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
- After a few minutes, the connected light on the booster should turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
Message posted on 03 Feb 2026 10:23 PM
every now & then i have only 2 lights green
