This discussion topic has been answered Discussion topic: Sky down again ash vale
Message posted on 07 Feb 2026 04:24 PM
Has anyone got problems with sky Tv today
Message posted on 07 Feb 2026 04:27 PM
Probably a few people in the UK or ROI but a Sky Q problem will almost certainly be an issue with your own set up. Any error message on screen?
Message posted on 07 Feb 2026 04:30 PM
Re: Sky down again ash vale
No satellite signal you are not connected to your box, the main box won't even come on now I went into my account and it tested the broadband has a problem
Message posted on 07 Feb 2026 04:39 PM
With a “no satellite signal” error message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️(short lasting) very heavy rain or
▫️snow on the dish/LNB in winter
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 adverse weather can affect the satellite signal and following such events wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
