Discussion topic: Sky continually cutting out
Message posted on 15 Aug 2026 08:10 PM
I am fed up having to reboot my Sky box. It cuts out several times a day and I have to go through the process of switching off then going through the procedure to restore it. Can any one help . My Sky box to me is a bit too hot.
Message posted on 15 Aug 2026 08:50 PM
Re: Sky continually cutting out
Hi @JR6731
