Discussion topic: Sky card unauthorised problem
Message posted on 11 Jul 2023 12:52 PM
Hi my mums sky box keeps saying there's a sky card not authorised on certain channels when usually she can see them
Message posted on 11 Jul 2023 05:13 PM
Re: Sky card unauthorised problem
@Suelou Have you tried rebooting your main Q box ie
if that doesn't work
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
