Discussion topic: Sky box
This message was authored by: Kelly241
Sky box
Sky box has no blue light.
Re: Sky box
Hi @Kelly241   Have you tried a power reboot?
Re: Sky box
@Kelly241
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
▪️I AM NOT A SKY EMPLOYEE ▪️
