Discussion topic: Sky box without cables
Message posted on 20 Oct 2026 03:45 PM
Hi all! So how do people have their tv mounted on the wall without all the cables showing? Is it possible to have a sky box without the hideous thick cables attached to it?!
Message posted on 20 Oct 2026 03:53 PM
Re: Sky box without cables
@LouiseHB86 wrote:Is it possible to have a sky box without the hideous thick cables attached to it?!
No. All boxes require a power lead and HDMI cable at least.
@LouiseHB86 wrote:Hi all! So how do people have their tv mounted on the wall without all the cables showing?
Various options but will require some DIY. Easier options would be some cable ducting.
Message posted on 20 Oct 2026 04:05 PM
@LouiseHB86 wrote:Hi all! So how do people have their tv mounted on the wall without all the cables showing? Is it possible to have a sky box without the hideous thick cables attached to it?!
If your TV has the NOW app you can stream all Sky programming directly without the need for any additional box or puck.
NOW is also run by Sky and offers individual Entertainment, Cinema and Sports packages on monthly, 6 monthly or annual contracts.
If unsightly cabling is an issue for you and you don't want the expense of creating and hiding cable ducting, then this can be the ideal alternative means of getting Sky content.
