Discussion topic: Sky box not working
This message was authored by: Cooper9
Sky box not working
Tried everything sky box not working been tri g now 2 hours just not acceptable
Re: Sky box not working
@Cooper9  Your post has been moved fromthe Sky+ Board as you previously posted about issues with Sky Q and unlikely you have reverted back to Sky+ as that is not an option.
hi @Cooper9
what error mesages etc ar you getting ?
BTW you should note that SKY +/HD is no longer fully supported by SKY but others here may be able to help you depending on what the problems are
Edit:  I see your post has been moved to SKY Q
