Discussion topic: Sky box not working
Message posted on 13 Jan 2024 10:55 AM
Sky box not working
Message appearing.
"Please check the power of the device and cable connection status" How do I fix this?
Message posted on 13 Jan 2024 11:01 AM
Re: Sky box not working
@MichaelFewer wrote:
Message appearing.
That is a TV message saying basically that it cannot see any device connected to the TV HDMI input.
Remove the HDMI cable ftom the TV and the Q box and then refit it making sure that is corrected fitted.
Check that the TV is switched to the correct HDMI input and try powering on the Q box again.
Message posted on 13 Jan 2024 11:55 AM
Thank you.
This did not rectify the problem.
Message posted on 13 Jan 2024 11:57 AM - last edited: 13 Jan 2024 11:58 AM
@MichaelFewer Using the Sky Q remote try the following commands on the remote Home 1080 Home
This should set the boxes resolution to 1080, then try cycling through the HDMI inputs using your TV remote.
