5
This discussion topic has been answered Discussion topic: Sky box not working
This message was authored by: PS18785
Sky box not working
Sky mini box not starting says wait for screen to go blank and press home but light on box stays orange
Re: Sky box not working
Hi @PS18785
Have you tried to switch the mini box on by pressing the Standby button on the front right of the box (the Amber led).
If this brings the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @PS18785
This message was authored by: bucklanjohn1
Re: Sky box not working it is the old box
The old box says there is a problem so switch every thing off but to no avail
This message was authored by: tel+davis
When watching a recording programme..it just freezing and it doesn't fast forward
This message was authored by: Kingben1956
Yes it is stucknon the orange light
This message was authored by: Edmond2
Is still not working
