Discussion topic: Sky box not turn on
This message was authored by: Jamiebrown19
Sky box not turn on
Hi
my sky box anf mini boxes are not turning on
Re: Sky box not turn on
@Jamiebrown19 wrote:
Hi
Hi @Jamiebrown19
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
