Discussion topic: Sky box not responding
This message was authored by: susan125
Box does not respond until everything has been switched off, new batteries have been installed in handset
Re: Sky box not responding
Hi @susan125
First reboot the Q box
Then with the Q box on with green led try completly resetting your Bluetooth remote.
