Discussion topic: Sky box issues
This message was authored by: NABZH1978
Sky box issues
My sky box for quite some time has been playing up. It often freezes where by i cant change channels, pause or rewind.
But something that has been happening for many months now is some channels won't let me pause, revind unless I change channels.
I was given a new remote but that hasn't made a difference
What should I do please
Re: Sky box issues
Hi @NABZH1978
