Discussion topic: Sky box has no power after local power cut
This message was authored by: Gin5
My Sky boxes appears to have no power after a power cut, we also have no WiFi at the moment.
Re: Sky box has no power after local power cut
Hi @Gin5
Have you tried rebooting your Q box?
If you also have no WiFi then you may have a wider power issue.
Is the router powered up?
This message was authored by: hrai
If you literally mean no power (no lights, hard drive/fan noise) - especially after a powercut - I would suggest checking the fuse in the plug and the circuit breaker in your fuse box (Consumer Unit) If your router isn't powered on either that would also be my first port of call.
It's not impossible that a powercut tripped a MCB and/or blew a fuse (the latter seems less likely but you never know)
