Discussion topic: Sky box don't work.
This message was authored by: Garyfl
Sky box don't work.
My main sky box doesn't work,sometimes it say you have no Internet connection. I have re- entered the password but still no luck. I have two small sky boxes that work fine so there is no problem with the Internet. Could you help please.
Re: Sky box don't work.
@Garyfl Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
