Discussion topic: Sky box Q
Message posted on 15 Jan 2026 09:56 AM
Sky box Q
Message posted on 15 Jan 2026 11:31 AM
Re: Sky box Q
@Shuggy37 wrote:
I have error:MR104 My sky mini box is not connecting to my sky Q box.
Hi @Shuggy37
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
