Discussion topic: Sky apps have no internet connection
Message posted on 15 Aug 2023 12:16 PM
Cannot access any apps on my skyQ box. It's telling me it has no internet connection, but my internet provider is working. Also I have forgotten my password for skygo.
Message posted on 15 Aug 2023 12:25 PM
							Re: Sky apps have no internet connection
Hi @Fitz
Your internet may be working but unfortunately it would appear that your Q box is not connected to it.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
