Discussion topic: Sky a mini
This message was authored by: Chris3010
Sky a mini
My sky q mini keeps losing connection to WiFi and satellite signal making it impossible to watch tv this is an on going issue and I'm starting to get fed up of it what's the best way to fix this
Re: Sky a mini
Hi @Chris3010
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
