Discussion topic: Sky a mini box
This message was authored by: Hitman
Sky a mini box
Sky q mini box not working, keeps saying no video available, can I have an engineer to sort it out please
Re: Sky a mini box
Hi @Hitman
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
To help connect your mini try the following.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Avatar for Hitman
Level 0 icon
Re: Sky a mini box . Need an engineer to sort out, keeps saying no video available
Only had sky q for a week. Mini box  keeps saying no video available so can't watch anything. Need engineers to sort out please
See my previous post @Hitman
