18 Aug 2024 04:25 PM
My sky q mini box has stopped working, keeps saying no satalite signal, main box working fine, broadband connect is really slow at the moment but all other boxes working fine and internet connection. Went through all the fix steps advised for a new box, box delivered within 16 hours, added new boxes wires etc and still the same won't connect, tried rebooting, tried off and on with connection to main box absolutely nothing.
18 Aug 2024 04:30 PM
Reboot the mini as above.
