Discussion topic: Sky a box not working
This message was authored by: Angelfyfe
Switched the telly on , Apple TV , kodi box all working , sky a box not working and I'm getting a no signal message , changed the hdmi cable for a new one and the box still won't come on , any ideas ?
Re: Sky a box not working
Hi @Angelfyfe
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for Angelfyfe
Hi thank you for advice but no lights coming on the box no matter what I press , box seems completely dead 😱
Pulled the power at the wall?
