Discussion topic: Sky a box keeps losing connection
Message posted on 26 Feb 2025 11:33 AM
I keep the messsge 'it looks like you do not have internet connection right now etc' whenever I put sky on from standby. If I switch off the box and reboot it works, but I have to do this every time I put sky on
help?
Message posted on 26 Feb 2025 12:03 PM
Re: Sky a box keeps losing connection
help?
