Discussion topic: Sky TV not working
Message posted on 24 Aug 2024 10:03 AM
Sky TV not working
Satellite signal doesn't work especially when trying to watch live events
Message posted on 24 Aug 2024 10:04 AM
Re: Sky TV not working
@Gareth882
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 24 Aug 2024 10:04 AM - last edited: 24 Aug 2024 10:05 AM
Hi @Gareth882
Deleted
Alread posted
