3
This discussion topic has been answered Discussion topic: Sky Sports
This message was authored by: scubawho
Sky Sports
Can you get all of sky sports for two months
Moderator Actions: Changed title to better reflect query
This message was authored by: PandJ2020 Answer
Re: Terminal cancer
Ignore the advice above.  (Although you can use NowTV but will require a device that can host the app - some Smart TV's do have it)
As you have Q then you should be able to subscribe to Sports on a rolling basis (without discounts).  You can then cancel it at any time giving 31 days notice.  You will need to call Sky to set this up.
This message was authored by: DaveDrizen
Re: Terminal cancer
I dont think so you have to have a minimum term of at least 12 months. However you can get  now tv which is actuly Sky giving you many of the Sky entertainment channels skys cinema and all the sky sports channels You can get this by purchasing as all now tv box that conexts to your tv  the same way you would connect sky box. There is no minimum term you h e it chast for a month at. time just cancel before the next month you want to stop
Re: Terminal cancer
You can get the box from Amazon
Re: Terminal cancer
