Discussion topic: Sky Sports Help
This message was authored by: Saints8
Sky Sports Help
I am subscribed to sky sports and has been working fine, just turned on today and it's telling me I need to upgrade. Just checked my bill and subscription is live... any ideas as it's impossible to actually talk to sky...!!!!
Re: Sky Sports Help
@Saints8 Have you tried rebooting your main Q box ie
if that doesn't work
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
